Is the lateral assembly supposed to sit on the bottom of the filter? The old one was just a little more than half way down. The top of the down pipe was cracked so I repaired it and extended it so that it sits on the bottom.
I'm not sure--you might need to see if you can find an exploded view of your filter via the internet. I found one for mine, before I started taking it apart......
Well it's been about a week I got the filter back running and am using DE in it and today I can see the pattern on the bottom of the pool, finally I can see the light at the end of the tunnel.
Thank You all for your help
Excellent!
Great! We got to use our pool all day Sunday- friends over, good BBQ, etc... you should be there soon!
