Re: Pool Questions
		It's difficult to tell if it's actually clear or not, I detect maybe the slightest hint of cloudiness in the deep end.  I'll keep running it to be on the safe side.  When can my children swim in it?  Obviously 31.5 ppm is pretty high, is it absolutely unsafe?  What level should I let it drop to in order to allow swimming?
Re: Pool Questions
		31.5 is not unsafe, but it is very hard on swimwear (depending on your stabilizer level) and might be uncomfortable. Assuming your CYA is still ~60 ppm, I'd let my kids get in at 20 ppm, but with older swim suits.
If your pool is clear, you can start cycling it. But try to have it run 2x per day for a total of at least 6 hours (more, with a sand filter).
Re: Pool Questions
		This morning the chlorine reading was 17.5 ppm... is that a drastic drop in 24 hrs?  From 31.5 to 17.5?  The pool is clear, clean & blue.
Re: Pool Questions
		If you added chlorine after the sun was low enough to end most direct sun, and then retested before there was much direct sun . . . then yes, that's a drastic drop.
Otherwise, no.
But if your water is clear, I'd go ahead and let it drop to the 5 - 10 range and hold it there for a week. After that you can operated normally. But do follow the Best Guess Guide  (link below) to establish what "normal" is for your pool. At 60 ppm CYA, 5 - 10 ppm chlorine IS normal.
Ben
