I think I have found the promised land, and it is here! I know next to nothing about caring for a pool, but I married into a 13x25 ("portable"? come on...) above ground Legacy pool about 1 1/2 years ago. When my wife and I got together 3 1/2 years ago, it was mostly empty and very scuzzy. She had it drained, cleaned, and set up, and other than adding shock and pucks, and vacuuming and cartridge cleaning, it stayed chemically correct year-round. Until this year.
I worked out of town a LOT this off-season, and frankly just let it go. I live in the high desert in California, which means LOTS of heat, sun, and high winds full of blowing dirt. Add to that a neighbor's constantly shedding tree, we wound up with a thick layer of gunk on the bottom. Vacuum, clean filter, repeat. Over and over. Maybe I should have drained it and started fresh, but oh well. I got it mostly clean, except for very cloudy water that would not clear. The XStream cartridge was 5 years old, and having been hosed down and cleaned so many times, I thought I'd replace it. Still cloudy water.
The new cartridge came with a free pack of Pooltime test strips. According to their online tester, I needed about $75 worth of stuff to "fix" it. Ph down, metal/scale/stain stuff, clarifier, algicide, shock, etc. I went to the local pool shop to see if they had what I thought I needed. Surprisingly (from what I've read here), they said to hold off on the stuff and just bring in a sample and they would test it for me. Results turned out that all levels were fine, with the exception of free chlorine. To help with the murkiness, they said I could go with bleach, but suggested I get liquid chlorine from them for about the same cost in the long run. I bought 4 gallons for under $20, with a $5 deposit on the crate and bottles. They said to add 1 gallon at first, then 1 quart - wait - test - repeat. For 2 days I noticed no difference. Then I stumbled across this site.
The pool shop neglected to mention the effects of sun, and that too much chlorine wasn't neccessarily a bad thing. Before bed last night (and after finding this forum), I added a full gallon of liquid chlorine. This morning the water was about 50% clearer than yesterday. I vacuumed, then removed and cleaned the very green cartridge. Just now I added my last gallon, and anticipate more results in the morning. I have spent the better part of today reading this forum, and have become a believer. I need to get a better test kit, as mine doesn't do FC and CC, just TC, but tomorrow I will return with my readings and ask for any advice you all may have. And I promise to learn P.O.P.P.
Reading this forum has taught me sooooooo much today.....
odddon
