Is it OK to use plain jane blue vacuum hose from Home Depot on one of these, or Hayward is adamant about using only their hose on a Navigator pool vac?
Is this a simple suction-side vacuum that goes in the low drain or skimmer? If so, then any hose of the right size should be fine.
If it's a pressure-based vacuum then you probably need a floating hose for it to work correctly.
