All the numbers are right on except the PH which is really really high. Any suggestions
You can use muriatic acid to lower pH. If you can give us some current water testing results taken with a drops-based kit preferably instead of test strips, somebody here can better advise you. Also, tell us what kind of pool you have and the volume and what all you have been adding to your pool (ingredients, not just "shock")
By the way -- I moved your thread into the saltwater forum. Saltwater systems sometimes have chem levels and specifics that are different from regular systems. That way, you will get more appropriate suggestions for your setup.
Welcome to the Pool Forum!
