Center Pipe in sand filter breaking
Hello everyone.
I have a weird problem. Both this year and last year I had to replace the entire lateral assembly in my sand filter because the center pipe broke. Last year, I thought it was because it was just old--the filter is about 10 years old. This year, it happened again. Both times it happened about 3-4 weeks after we opened the pool and started running the filter.
I asked the guy at the pool store where I bought the assembly if he knew of any reason why this kept happening, and he said that the only reason he had ever heard of for this was that the filter froze over the winter. I don't see how that could be the issue--we drain the filter every year. Also, if that was the problem, wouldn't it have been broken and sand going into the pool from the time that we first start running the filter for the year?
Thanks in advance for your help!
Shari
Re: Center Pipe in sand filter breaking
Hi Shari and welcome to the forum. If it was freeze damage I too would think it would show up as soon as you turned it on, not 3-4 weeks after. At this point all I have are some questions. Is it a top or side mount valve assembly and what is the filter make/model? Reason I ask about top/side is the internal plumbing is different. The way you mentioned the 'center pipe' it sounds like a top mount. Also, what kind of a break was it and was it the same both times? Describe it the best you can.
Poconos
It's a top mount Hayward Pro Series S180T. For the first break, (last year) the top 3 or 4 inches of the pipe broke right off, with a split going down to about 3 inches below it, and there was also a crack going up about 2 inches from the bottom. The second break (this year) the pipe almost looked as if it had been twisted--there was a split all the way down from the top to the bottom, with cracks/splits radiating down horizontally along the split.
Shari
Bumping this to the top hoping someone can figure this out...should I buy a spare lateral assembly online so I have one if it breaks again? I can get one a LOT cheaper online than I can from the local pool store.
Shari
Sure looks like freeze damage but still don't understand why it didn't show up immediately and also why it was damaged in the first place. If it wasn't drained completely then the damage at the bottom could be explained, partially, but the top????? I really can't think of any scenario that would cause this.
Anyone else with ideas?
What size pump do you have? Your filter is a 150lb sand filter. If your pump is too big it could damage your filter.
Let's rule that out as a cause first.
It's a 1 hp pump--same as I've had since we got the pool 10 years ago.
Shari
More long shots. When you replaced the sand did you partially fill the tank with water first, before adding the sand? This is done to let the sand evenly fill the tank without stressing any of the internal plumbing. After you filled the tank with sand did the center pipe stay centered so you didn't have to stress it to mate with the valve assembly? As I said, log shots but I have to mention them. I'm heading in the direction of anything putting stress on that center pipe. On the pump, even if it was way oversized I don't see that causing the problems you describe. I'm still stumped.
Poconos
We did partially fill the tank with water first. I don't remember having to force the pipe into "mating" with the valve assembly, but we may have had to. I'll ask the people who were helping me do it. I did remember one thing--both times, it happened right after I had backwashed the filter because the pressure got too high. The backwashing went fine, the rinsing went fine, and when I put it back on the filter setting there was a kind of shudder when I turned the pump back on, and sand started pouring out of the return.
I am watching the pressure really carefully now and making sure it doesn't get too high--I'm probably backwashing too often, now--I do it if the pressure rises much over 5 from what it is when the filter is clean.
Shari
Backwashing at a 5 psi rise is fine. In fact I do mine less than that unless I'm vacuuming a lot of junk. There is truth to the idea that the crummier the sand gets the better it filters but if I want better filtration I throw some DE in the thing. As I said above I still can't imagine high pressure due to dirt causing the problem. Anyone else want to chime in here with any ideas no matter how bizarre they may be?
