Re: Hayward H100ID troubles
Anyone that might be interested I do believe I have solved my problem. The ignitor wire (8mm sparkplug wire) has a break in it somewhere which was allowing the higher voltage to the ignitor but was not allowing the low voltage back to the contol panel to keep the gas valve open. This break was also somehow tripping the GFCI circuit breaker. I replaced the wire with a "temp" wire and all is well. I hope this post helps someone down the road, thanks.
rusty
Rusty, Thanks for the followup. You probably didn't get any responses because anyone familiar with this heater hasn't been on the forum. Glad you solved it though. And BTW: Welcome to the forum.
