Just got done hard piping my ABG pool pump, Did I do good?
I did see a small error in my Natures2 bypass that I will need to fix.
http://s22.photobucket.com/albums/b302/britisharmy/?action=view¤t=Poolplumbing.jpg
Can't tell as I can't view the pic. With the forum in a very dynamic state right now I'm not surprised. If it works and doesn't leak you did well.
Welcome to the forum!
As Al said, I'm not seeing a pic and as long as you don't see drips of water at the connections you made, all ought be good :cool:
I'm biased. Totally biased.
My view of a Nature2 setup is to totally and permanently bypass it, cut the darned thing out, and see how far from the dumpster you can be and STILL get it in. Bonus points if it smashes in the dumpster.
But then, as I said, I'm biased.
It's supposed to reduce your chlorine usage but the cost of the unit and the annual cartridges is FAR greater than the cost of the chlorine you don't use.
But, as I said...I'm biased.:rolleyes:
Don't mind me--and WELCOME TO POOL FORUM!
