Re: question about alk level
If the pH is low then the TA could very possibly be 0 ppm and the indicator will turn red immediately. Trichlor is acidic and eats up TA over time and causes the pH to crash.
TA is the measure of bicarbonates in the water.
When the pH is very low the bicarbonates have been converted into carbonic acid and therefore not measurable by the TA test. Effectively, there is no carbonate alkalinity in the water since it is all in acid form.
LazyLgrecian
I used to a paper with how and what amounts a gallon of 6% bleach, a pound of trichlor and a pound of dichlor had on 10K gallons of water , for ph cya and TA. is that table still here somewhere?
I'm not sure that I ever saw that table, but I can tell you that one gallon of 6% bleach will provide 6 ppm Chlorine in 10 gallons of water. I also can tell you that for about every 10 ppm chlorine obtained with trichlor, you raise your CYA by about 5 ppm. Trichlor will drop your TA and pH, but how much it drops your pH depends on your alk level. I've never used dichlor so I can't advise you about that, but I do believe that dichlor isn't quite as acidic as the trichlor is.
Dichlor is less acidic than trichlor but the net results are still acidic and for every 10 ppm fc added it will add 9 ppm CYA.
