Leaking Salt Cell.
My Ecomatic salt cell is leaking slightly at the thru holes where the power cord is attached to the cell. I assume there are either some kind of o-ring or washer between the plastic nuts but I can't find a detailed view or parts list anywhere. I don't want to pull it apart until I have the replacement parts since once I do my pool is down until i get it fixed..
Any suggestions on a good spot to look on line? I hear Balboa is no longer making the cells so I hope there are still parts available. One thought is to replace the cell and then rebuild this one and keep it as a replacement since the future availability is iffy ... thought?
Could it be as easy as needing to lube the o-ring ? the leak is intermittent.
ESC 36
