Tuesday I came home from work to strange noises from the pool and immediately noticed the water level was way down and the skimmer was sucking air. I opened the equipment shed and it was flooded and everything had been sprayed with pool water. I found that one of the PVC welds had failed and the main line from the filter had opened up. The previous owner or pool contractor had used a short length of strange pipe that appeared to have been flexible at one time. It was translucent and looked like it had coiled wire imbedded in the plastic. It also was clear that the original weld had never fused this pipe so it was waiting to blow all these years.
Has anyone heard of this kind of pipe being used? I am posting this more as a heads-up to others but I would like to know if this pipe is in common usage out there. :confused:
