Re: zapped jandy SWG cell
We've experienced similar results on our cells too. This is usually from water getting into the cell to cell cord connection. Sprinklers and leaks are the typical causes, but also from the cell being removed for cleaning or acid washing and the terminals not being dried off before the cell cord is plugged back on.
More than likely, if you're able to get the cell cord off, as long as the cell to cord connection is tight, you can still use the cell. If it's sloppy, you may have to replace the cell too.
