I have a question concerning testing for Cl when using a salt generator. We installed a Jandy unit last Friday. After the 24 hour waiting period we turned it on and set it at 100% for 24 hours. I then set it back to 55%. I have tested the water twice since then and gotten the same readings; 1.5ppm TC, .5ppm FC. I can turn up the % to increase the TC, but I am a bit surprised that the FC is staying so low. I would have thought that the constant CL flow would have kept these numbers closer together. Any thoughts on this issue would be appreciated. I can shock with some shock which I have, but I was hoping to get away from that.
