Hello,
After 6 weeks with no use of pool equipment because of it melting we now have our pool up and running again as of Thursday. Here are my numbers:
FC 7
CC 0
TC 7
pH 7.5
Alk 70
Cal 80
Temp 65
CYA unknown because I used up solution in August.
The Polaris vacuum worked fully on Thursday. On Friday it frequently stopped driving around. Today, it won't travel at all. I picked it up out of the water and observed that water is still shooting out of the center part that fills the debris bag. Water also shoots out the back (I assume that is what is suppose to make it travel) and out of a section of the attached hose about 3 feet from the actual vacuum. Any ideas on what could be causing the Polaris to stop moving even though I see water traveling through it?
Shannon
