cleaning filter grid
After closing my pool I soak the DE filter grid in a barrel before storage.I have used a store bought chemical to clean it .I believe muratic acid can be used to clean it and I would like to know the amount needed. I'm sure this has been posted before but I can't find the answer ,Thanks for the help.
Re: cleaning filter grid
I've never done it because I have a sand filter, but maybe this thread will help...
http://www.poolforum.com/pf2/showthr...+muriatic+acid
Thanks for the info ,I think I will go with the 1 to 20 ratio with the acid. I have the grid type element . Going to put it in the barrel and let it soak overnight . I really appreciate the reply.l
When I clean my grids, I use about 1 pint MA in about 3 gal of water. Never thought about what the ratio should be. I let them soak for about 10 minutes and brush them with a soft brush before a thorough rinse. That way, the reassembly is more fresh in my mind. The grids have always come really clean even with the short soaking time.
Hal
