Sand on bottom and water is dull (not sparkling)?
I have vacuumed the sand a couple of times now (not back into the filter) and it comes back. I am pretty sure this is a sandfilter issue. However, my water is also what I would call semi cloudy or dull. Could it be that small particles of sand from the filter is causing this? I have shocked without that helping but am trying again.
PH - 7.4
Chlorine - at shock level now. Typically keep it at 4-5
Bad Chlorine - 0
Stabilizer- 50
Alk - 90
I dont see any type of algie or anything similar, just sand. The sand is also mainly around the outer section of the 24' round pool. Basically the direction the return is blowing out.
Re: Sand on bottom and water is dull (not sparkling)?
The cloudiness is probably due to your filter not working right. Damaged laterals in the filter are a likely culprit.
JohnT
Thanks John. Now I have a dilemma. I plan on getting a new pentair sand filter, but do I wait or get it now? I am wondering if I need to clear the water up before winterizing of can it wait.
mjs31
If you have broken laterals in your filter (or anything else wrong with it that's letting the sand blow back), it's only going to get worse until you replace or fix it. I'd say that if you're planning to close your pool for the winter and are finished swimming in it now, wait until the spring to install your new filter and open with it. If you're going to leave the pool open throughout the winter, go ahead and get the new filter now, then clean up the sand in the pool.
aylad
Thanks. I will probably just close it up for now.
