New surface still needs daily acid
We have an IG gunite 13,000 gal pool, which was resurfaced in Feb with a quartz-type surface. The pool guy handle chemistry for the first month and then I took over again.
I have been fighting high pH ever since and need to add acid almost daily. I don't have all my numbers in front of me, but
ALK is ~ 110
CH is ~ 150 ( our water is hard)
I am trying to understand if I have a chemistry issue or this is normal for the first year of a new surface.
Re: New surface still needs daily acid
FWIW, my IG is 5 months old (gunnite/plaster) and I still battle high ph, though it is lessening. Typically I need to add about 2.5 cups of muriatic acid every 3 days or so...my numbers typically look like this:
FC=7.5ppm
CC=0
PH=7.8
CYA=55ppm
CH=375ppm
TA=120ppm
My TA was 210ppm at filling, so it is making its way down.
