latest results and pool is hard on eyes...
My eyes are not that comfortable in our pool, not sure why. Here is the latest:
fc: 1
cc: 0
tc: 1
ph: 7.4
alk: 50
cal: 150
cya: 60
gallons: 28K
thinking about:
14 lbs of baking soda (6 lbs, re-test, then 2lbs re-test until 14)
25 lbs of calcium
does this make sense? And why are my eyes smarting? I thought that was related to PH and my PH looks fine...
tia,
jd
Re: latest results and pool is hard on eyes...
Looks like you ALK is low. Should be at least 100-130 ish. I'd do baking soda for sure. Start small and maybe add 8-10 pounds and see what that does in 24 hours.
With a cya of 60 you should have your chlorine at a minimum of 5ppms. With an alkalinity of 50, calcium at 150 and ph at 7.4, your pool is slightly acidic. I would bump the alk up with baking soda, as traceyb said, and it should take your ph up slightly also. If you have a vinyl liner you don't need calcium, but if you have a plaster pool you will have to take your calcium up to 250.
