Re: Pool Store Test Results
LFRoberts5
			These are the results I just got back from the Pool Store.
FC 2.4
TC 3.2
CC 0.8
TA 131
pH 7.6
CYA 47
This is after adding 4# of CYA and letting the pump run for about 4 days to let it all dissolve.
I have a 11,000 AG vinyl liner pool.
Any suggestions as to how the numbers look and what I should do?
THANKS!
Lloyd
  Your numbers don't look bad, except that I would shock it to get rid of that CC.  Also, I'm not so sure that your CYA has finished dissolving in the water--it wouldn't suprise me to see it increase a bit more.  How does the water look?
		Right now the water looks great!. How long do you think before all of the CYA is dissolved?
		It can take up to a week or so for all of it to dissolve.
		Do I need to leave the pump running the whole time or just make sure I don't backwash it?
		Just don't backwash. You don't need to run the pump.
But you do need to get your FC up to shock levels to get rid of that CC.  I believe 15 is the FC you need.  Then you should be just fine.
		Here is a new test.
FC 1.9
TC 2.0
CC 0.1
TA 118
pH 7.8
CYA 45
My question is:
When do you need to shock a pool?
When ever there is a trace of CC?
THANKS!
