I recently notice small air bubbles from the water flow leaving the filter going back into the pool. Any thoughts or suggestions?
Sounds like a suction side leak (sucking in air at a joint or crack between the pool and the pump input). If it were on the side after the pump output (pressure side) you would have a water leak somewhere. This is a guess on my part... any other ideas from folks w/ more experience??? Can you see bubbles in the pump basket while the pump is running?
