200lbs sand in a 250lb filter
I know those goof balls that installed my pool only put 200 lbs of sand in my filter and it states that it holds 250lbs. I have had a great looking pool since last july and don't want to mess with something that isn't broke, but I guess when I clean out the sand, and refill, I will use FIVE bags instead of just FOUR bags right? And the pool store also told us that soft swimmers must change yearly and chlorine swimmers have about 3 years before they need to change. ANYONE?
Re: 200lbs sand in a 250lb filter
traceyb
They are right about biguanide pools having to change sand often, but chlorine pools seldom need the sand changed. For certain not every three years.
Ditto to what John said. Sand has been in many chlorine based filters ten years or so.
I would simply add the fifty lbs at my leisure. Your pressure will increase some but you'll get additional filtering capacity.
I'm having no problems in the 5th year of my sand--in fact it's filtering better than ever.
Oh how nice it is to hear you all say this. I can only imagine how much of a pain in the batoootie it is to CHANGE the sand. The pool is new as of 7.2006, so I suppose I have several years yet eh? I just heard that it's good to change it about every 2-3 years so the filter job is better. A friend of mine stated that in their oval AG the water gets cloudy, they change the sand and waa laa. However, I don't want to get in the situation where the pool is open for the season THEN have to change sand. THAT could make matters no fun.
So, when it IS time to change is a shop vac the best way to get that out? I hear your not supposed to "roll" the filter for risk you might break a "lateral head"
