Re: Low PH and Alkalinity
		You can use washing soda, as explained in this post by CarlD:
 Baking Soda does not raise pH significantly but it does raise Total Alkalinity  (TA).
All Chem_Geek was suggesting was that since you need to raise both pH and TA, you can use Arm&Hammer Washing Soda (in the Yellow box) rather than using both Baking Soda and Borax.
Why would you do this? Generally, pound for pound, at the supermarket Washing Soda is a little cheaper than Borax. But more importantly you only need to add one chem to get both effects.
99 times out a 100, I'll use Borax to raise pH, especially since I'm generally facing higher TA levels (140 or so--which is fine in vinyl pool with no heater). Borax won't increase TA levels, sort of. Washing Soda will. (as pH rises and falls, TA goes up and down with it. W/S raises the TA more than the pH rise does alone.)
So the other day my pH was 6.9 (VERY unusual for me) and my TA was 50. IDEAL conditions for using Washing Soda rather than Borax and Baking soda.
You can pour the washing soda right in the skimmer, slowly so that it doesn't go all over the place - how much depends on how much water your pool holds;)
		Washing Soda is the same chemical sold expensively as "pH Up" and other amazing names and packages that justify a price 3 or 4 times that of Washing Soda.
Both are Sodium Carbonate (NOT the same as Sodium BI-Carbonate--baking soda).
		It's a 13,500 gallon pool (24' x 48").  Where might I find how much to add?
		Try adding 2 cups, wait 2 hours, test again and see how much it went up - then take it from there.
mbar
  Thank you!
