Re: Old solar cover disposal
unless it's got the recycle logo on it, you're likely going to be hard pressed finding anyone who will take it.
Try calling your local recycle center and they should be able to tell you, if someone tells you yes - get their name, because htere's nothing worse that showing up to drop it off and the next guy tells you no.
May be handy to cut some of the good sections and save them for maybe covering sections of the pool that the regular cover doesn't cover or cushions to lay things on like a rolled up solar cover. If you have use for these good sections at least it will cut down on the quantity of what you need to trash. As a last resort if you're into bonfires the stuff melts down to nothing.
My old liner and old solar blanket made great underlayment for the rock garden I installed around the pool perimeter.
Thanks all, I'll try to recycle and if that fails I'll reuse creatively. If I can recycle I'll report back.
C.
