Polaris Autoclear Plus error 94
Help!
I keep getting error code 94 on my Polaris Autoclear Plus. We cleaned the cell and our salt level is fine so we moved on to the possibility of a cut cord. The cords/wires are fine and all the connections are tight. When we push Test and it runs through the salt,output amps and voltage....the amps show zero.
My husband is pretty handy electronically but we are worried about voiding the warranty. The unit has been installed for exactly 2 years. Any thoughts?
Thanks!
Re: Polaris Autoclear Plus error 94
Sorry not versed in Polaris errors. However, with AutoPilot, a low amp condition is usually tied to the cell, cell cord, or cell fuse...or no salt in the water.
I believe also that if the temperature is not set properly, the unit will not operate.
Have you tried calling Polaris troubleshooting tech line?
Thanks Sean. It ended up being a fuse. Quick and easy fix. Thank goodness.
