It's all done but the fillin'
Just waiting for some fill water, so I took some baseline measurements from the tap to see the fill water chemistry:
FC =<.2ppm
CC 0ppm
TC =<.2ppm
PH 7.4
TA 180
CH 190
I used the Taylor FAS-DPD kit. We're getting pretty excited! Didn't bother with CYA as I figured there wouldn't be any.
A BIG THANK YOU to all the experienced here, I really appreciate the help and knowledge passed along in this forum. What a great group of people!
Re: It's all done but the fillin'
steveinaz
FC =<.2ppm
CC 0ppm
TC =<.2ppm
PH 7.4
TA 180
CH 190
I used the super-fancy Taylor kit (don't now the number). We're getting pretty excited! Didn't bother with CYA as I figured there wouldn't be any.
Congratulations on the pool, and the good news is it doesn't look like you're going to have to adjust much with your water, either! Happy swimming!
Thanks Janet, we're pretty excited. Looks like I should probably raise Calcium (of course chlorine) some (plaster finish). The high-side TA number has me a little worried.
Steve, congrats on the new pool! As Janet said, the numbers are good as they stand, but if you'd like to add ~ 50 ppm of calcium, it wouldn't hurt. I've 'run' your numbers on the Watergram that came with my Taylor kit, and for any water temp you're likely to have, the water is within ballance. (If you'd like to read a little about the Watergram/ satration index - see Donnies current post - it's one of the ones that is being updated daily right now, so should show up if you hit the 'NewPosts' option at the top of the page - for more technichal and detailed info, there's a post in the china shop on the indecies).
If you want to add cal and cl at the same time you can use calcium hypochlorite (granular chlorine) to raise them both, or you can use bleach and calcium flakes to do the same thing. **One caution, it's usually advised NOT to add salt for 2 - 4 weeks after new plaster is applied ( if you want the links, I can dig them up), so you will need to 'manually' add chlorine durring that time. This may be a good oppertunity for you to use bleach, cal-hypo, and trichlor pucks (the moderator Poconos uses all 3 durring a season) as you definately want to get some cl and cya in there and could stand to have a bit more calcium.
I'm purposely not going into too much detail here, but if you want a little more detail, I and the others will be glad to provide it. Again, congrats on the pool!! :)
Thanks, I'm definitely going to make the PB wait 2-4 weeks before adding salt. I plan on using BBB until I get the SWCG running. Water temps at my friends house were about 48 degrees, so I'll probably need to rely on BBB for awhile. Once they start filling, I'll hit the local grocery and stock up on chems.
