Re: Inground pool cleaning.
The filter and pump should be sized together.
When you say cleaning system do you want an in-floor cleaning system or an automatic pool cleaner like a Polaris, Zodiac, etc.?
Josh
In floor, with the series of pop up heads etc.
Sorry for the confusion.
Alan
The mfr of in floor cleaning systems that I briefly considered is from Paramount. http://www.paramountpoolproducts.com/index.php
I decided against the system mainly for cost reasons. I have not used the system but understand they work well in climates where you are trying to move sand and fine particles to the main drain. From what I understand the in floor systems dont work as well on heavy leaves, etc.
I am going to get the paramount MDX drains and canister installed though. Just in case I want to sweep leaves or whatever to the main drain I like that it goes to a skimmer like canister poolside.
I am not familiar with any other mfr of in floor cleaning systems.
I've never personally dealt with an in-floor system however these are two more vendors to consider:
Polaris:
http://www.polarispoolsystems.com/pr...sp?ID=In-Floor
A&A:
http://www.aamfg.com/
Josh
Thanks for the information... yes that's my primary reason for the in-floor lots of blowing sand here in Las Vegas.
Alan
