I have the ps233 test kit and use this to test CL in my pool. Is there any way to test bromine levels using this same kit? If the answer is no is there a kit you can recommend?
test your chlorine and multilply the results by 2.25 and you will get the equivalent ppm bromine reading. If you want a bromine specific kit I highly recommend the Taylor 2106 which is their FAS-DPD kit for bromine. It will test all paramters that you need in a bromine pool.
