Re: Have I missed anything?
I live in Thornhill. Your procedure sounds almost identical to mine.
You didn't mention a slide, but if you have one don't forget to blow out the water line to it.
Also, if your pump is like mine there should be 2 drain plugs to remove.
I usually raise my chlorine higher than 4, even as high as 10ppm. It will disappear over the winter, anyway. Did you cover the pool?
One other thing is to turn off the circuit breaker for the pump at the panel.
From what you have described you should be good.
Thanks for the reply.
Yep, removed the 2 plugs from the pump.
No slide, but I removed the ladder.
I covered the pool, but I think I want to insert a "pillow" or something to help support the cover this year. What do people typically use for this purpose?
I was thinking of raising my CL and I suppose I should.
I think my main worry right now is the main drain since it is basically just filled with water. I don't think the pool guy ever did anything but put some foam rope into it (which I did as well).
Can't you pressurize your main drain line (from near the pump) until bubbles start coming out of the drain? Then turn off the valve.
If the drain line was properly installed, it should run downhill from the pump all the way to a low point, and then run uphill all the way to the drain. That means that once bubbles are coming out of the drain, the section between the pump and the low spot should be completely filled with air. (It should take about 5 psi to do that if the water is about 10 feet deep at the low spot) At that point, while it is still bubbling, turn off the main drain valve. In theory, air should remain in the line all winter if the valve and pipe don't leak.
I don't have experience with this, so don't take my word for it. I do intend on doing my pool this way unless somebody knowledgeable says that it's a bad idea. (Then I'd like to know what you're "supposed" to do.)
In my case, my main drain runs from the bottom of my pool to a second opening in my skimmer. My skimmer goes down below the current water level in my pool so as soon as I open the main drain, it starts filling the skimmer.
I suppose I could lower the water even further, pressurise the main drain, then raise the water level up a bit.
Can anyone tell me if this is necessary? I know the pool guy didn't do that.
