Closing AG pool in North Texas
		Last year I didn't close the pool for the winter.  I basically raised the cya up a bit and kept it slightly chlorinated.  I continue to monitor ph and chlorine thru the winter but not as much as during the pool season.  I didn't drain the filter, i would still run it once a week and also if they were expecting the temps to drop below freezing.  Temps around here don't usually fall below 30 for more than a few days at a time.  Could this cause any problems?  I need to know before i do this again this winter.
		Re: Closing AG pool in North Texas
		Sounds like our climate here in NC.  I don't close my pool, either.  I use almost the same procedure for winter that you describe except that I make no effort to adjust CYA.  Are you doing that to hold your Chlorine as long as possible?
		Yes, i raise the cya just to maintain the chlorine in the pool a bit longer.  By spring time.  I will usually start adding water that my Cya has dropped back to usual setting for pool season.
