Re: SWG / ZeoBrite start-up
Test results would give some good clues.......without them, it's wild guessing.
Ok...since last Thursday (new pool and startup of all equipment) and even now. Pump on 24/7, water is still cloudy.
I decided to go to warehouse pool supply and get the water test done.
So they ran the test.
Here are the results:
total chlorine: 6.0 ppm
pH: 9.0
Hardness: 100 ppm
alkalinity 150 ppm
cyanuric acid: 10 ppm
total dissolved solids: 1400 ppm
~~~ end of test results they gave me ~~~~
So, the guys at pool warehouse sold me: Muriatic acid & Naural chemistry Clarifier.
They said all I need is this to get the pool clear.
So, as of today, my SWG is at 3200ppm @ 70 (setting); Filteration is "on".
I have all valves on: High and Low side outs on, main drain and suction. The filteration is on.
So by adding:4 pt/ 6 oz of muriatic acid and little bit of the Naural chemistry Clarifier, should my pool get clear in about 6hrs.
Last, but hope not a dumb question, but by putting in Muratic acid in my vinyl liner pool it is ok, right? Also where should I add the muratic acid at? By skimmer area?? Thanks 4 any input before I mess something up.
-Mike
