Have read lots and lots of information on this forum, but I may have missed this. Do you still need to keep trichlor sticks in your chlorinator when you're doing the BBB system?
I don't plan on using any other chlorine except bleach.
Thanks for the reply, Doggie! I thought that was the idea, but I just wanted to make sure!
Make sure that if you're leaving pucks or sticks in the chlorinator that you don't pour bleach directly in the skimmer...just in case there's a reaction.
Mccato,
The ONLY reason to keep pucks in your chlorinator is if you have less than ~30 ppm CYA. If you are at 30 ppm or above you should remove them or at least do not add any more when they are gone. (NOTE: this DOES NOT apply if you have a SWG system). There are many posts on the subject but if my memory serves me correctly the CYA goes up proportionately with the chlorine addition but never goes away:eek:
Thanks MaryLee and fcfrey - good advice. I appreciate the replies!
