Hello everyone,
I'm new to the forum and we inherited a 15,000 gal fiberglass pool with our house purchase last year. The pool has been great except for the fact that I cannot keep the pH anywhere near the 7.2-7.6 range I see recommended. I am worried about the heater failing due to the low pH readings I get.
The pool has a sand filter (6-7 years old and suspect for the low pH), heater, and I use tri-chlor tablets. I only "shock" the pool after pool parties which seems to be about monthly with Leslie's Fresh & Clear (potassium monopersulfate I believe) after pool parties. I used Calcium Hypochlorite last year but grew tired of the precipitant and the need to vac the pool after every "shock".
I keep planted aquariums and am very familiar with testing methods and know just enough chemistry to be dangerous :) All of the below tests were ran with Lamotte kits (all in date) with the exception of pH and TDS tests which were run with a freshly calibrated Hanna meter (accurate to 0.01 pH) Here are the results of the tests I ran tonight:
pH - 6.66 @ 72.7F (7.2 with LaMotte Pool Kit)
TDS - 1127ppm @ 72.7F
TA - 116ppm
FC - 1ppm
TC - 1.5ppm
Total Hardness - 228ppm
Ca - 144ppm
Mg - 84ppm
The only test I don't have a kit for is CYA. I suppose I could get it tested at the pool store tomorrow but I don't put much trust in them :)
Anyways, I'm open to suggestions as to how I can get my pH to keep from dropping. The sand filter will be changed out next spring unless I get recommendations to do it this fall.
I have went through nearly 80lbs of soda ash over the past two summers. I frequently add up to 4 lbs of soda ash to get anywhere from a 0.2 to 0.4 rise in pH but it is usually gone within a day or two. I know that volume of soda ash should raise the pH more, but it doesn't.
Just for an example, I had a pH of 7.0 this morning (LaMotte kit) so I added 2 lbs of Soda Ash. The pool filter ran all day (it runs 24/7 while the pool is open) and the pool sweep (Polaris 280) ran for about 2 hours after broadcasting the soda ash. I should have seen more than a 0.2 rise in pH after adding 2 lbs of Soda Ash!
Thanks and sorry for the lengthy first post but I wanted to give as much info as I could!
