Re: What am I doing wrong?
		Not sure about your pH question, but your chlorine needs to be a bit higher, like 3-6 and shock at 15, with a CYA of 35, according to Ben's Best Guess table
		Here are a few things to think about for your pH problem
Did you test your fill water for pH and ALK when you refilled your pool?
What test methods do you use?
Any fountains in the pool?
Does your water return break the surface?
When are you testing?
Where in the pool are you testing?
I found by testing next to the return my pH was higher. I am in the process of dropping my ALK slowly and checking for pH raise. Higher ALK in my pool caused my pH to run up every week.
		Still looking for answers
Test water was 7.8
I am testing with a drops tester...not perfect but repeatable results
No fountains
Return water has not been aerating the water generally
I test in the morning generally
I test from all over and I use a large baster to draw water from about 15-18" under water
The pool is presently not covered
I have heard and read that shocking the water is the way to go, but i dont understand it since the bleach has a high ph.
			Test water was 7.8
  Do you mean fill water?
