Re: Leaving town for 2 weeks
I would shock with bleach, add a tri-chlor puck in a floater and dose with polyquat just to be sure. With a cover, you should be fine.
Dave
Trichlor will dissolve much slower than cal-hypo, just keep in mind that it will also pull your pH down. I agree with David...shock it, put trichlor in a floater (make sure your pH is high enough to compensate and that you don't let it float to the edge of the pool) and cover it. The worst thing that will happen is that you'll have to shock it again when you get back...
