Re: Combined Chlorine Test
		Hi, Jake,
Those are surprisingly consistent results for pool stores.  It certainly sounds like there's something wrong with your test chemicals (probably) or your test methods (not likely).
It sounds like you'll need to replace some chemicals.
		Thanks Dave
I just got the FAS--DPD kit from Taylor 2 weeks ago --- and my R-0003 from the standard kit is fresh for 2006.  I've used both methods -- same results--no change in color (still clear with FAS-DPPD method) after adding that reagent!!
I wish Taylor would date their Reagents --- there doesn't seem to be any rhyme or reason to the batch number.:mad:
My results this morning are the same except FC dropped to 6.5 and the pH 7.5
My results for today are:---	   	Store Results
pH 7.7 by titration	----	   	7.3 -- 	7.6--	7.6
FC 7.5 ppm (FAS-DPD)---	   	5.9--  	5.2--	5+
TC 7.5 ppm (FAS-DPD)---	   	7.0 -- 	7.6--	??
CC 0 ppm (FAS-DPD)---	   	1.9--	2.4--	??
What kind of CL test returns results like  5.9 - 5.2 - 7.6 - 1.9 - 2.4 - etc???
		According to the MSDS sheet for Clorox Ultra 2, in addition to sodium hypo it contains Hydrogen peroxide 1-5%, Alkylbenzene sulfonic acid 6-10%, and Triethanolamine 1-5%.
Why would you want to add these extras to your pool?
I'd stick to the plain Clorox Ultra, or better yet the generic ultra bleach. Same stuff but cheaper.
Poolsolutions recommends staying away from the Clorox brands because they add "goo" to their bleach (http://www.poolsolutions.com/gd/bleach_0525.html) and here (http://www.poolsolutions.com/gd/ultrableach.html).
		See edit --- I had a brain fart --- it is standard Clorox Ultra.  Thanks for the catch!!
		Larry,
I use a FAS-DPD kit (Taylor K-1515A)---using a 25ml sample you will get a resolution on the end point within .2ppm --- That is 2/10ths
The results I posted were a mix of mine and pool store --- Some stores use a colorimeter which yields results to .1 but since I don't trust the stores techniques or calibrations (if they did any) --- you can probably round their numbers off to the nearest whole number.
				Originally Posted by Jakebear
			Larry,
  IF they are using a LaMotte Waterlink colorimeter then they are not waiting for the TC result to stop moving on the meter.  I have seen this happen where I work when inexperienced people do the test. The FC test needs to be read within 30 seconds and the TC needs to be read at 1 minute for accurate results!
		A few weeks ago when I was salting my pool I had the pool stores test my water. The results they gave me didnt agree with my testing for CC as well as pH. The tried to sell me shock and dry acid for a pH of 7.6. I have lost my faith in most pool store chemist.
Evan (waterbear) you know I dont include you in that statement. :D
The problem is that they are NOT chemists!  They just play one at work!:eek:
  I know....I would like to publicly announce that I take no offense at bashing pool store idiots...I bash them too! On another swimming pool board that I freqent I had the president of Orenda Technologies, who is an administrator of the board, send me a PM so I knew his negative comments about pool store personel did not apply to me! (He told someone not be be 'pool stored'!)  It's really very humbling to realize that industry professionals repect my opinions!  I have to give credit where credit is due....most of what I know about pools I learned on here and PoolSolutions!  I have Ben to thank for that!  Thanks Ben!!!
