My first test. Any suggestions?
Hi,
I have vinyl pool about 35k with 400k gas heater. Just put a new liner in about 1 month ago. My first "real" test results are as follows:
FC 6
CC 0
TC 6
ph ~7.3
Alk 110
Cal 150
Cya ~15
I have two puck floaters with non stabilized pucks. I added about 3# cya to get this far, but lost a few thousand gallons due to leak. I was planning on adding another 3# cya. I have several very small spots of black algae that I need to attack also. If anyone could let me know a good attack plan I would appreciate it. Thanks!
Re: My first test. Any suggestions?
Your test results look very good. I might suggest more CYA than you are planning. Use the bleachcalc but about 6 more lbs should get you about a 25ppm increase up to 40....that's the level I would shoot for.
Black algae is a tough customer. I have no experience with it but I believe the common method is constant high levels of chlorine and brushing as many times daily as you can. Others with more experience can help more.
I thought black algae had to have something to grow into (root) - like in plaster or concrete pools. Are you sure it's black algae?
