Originally Posted by B@rney
Hi guys,
Well I dont really have major problems, but Ive been trying to read up on stuff here in past threads and Im now even more confused.
Ok I have a 15` x 48" intex metal frame pool, with the intex SWG? (salt water generator) the thing that turns salt into chlorine.
I also have a solar cover which i keep on all the time.
Ok my questions are.
I seem to be having a bit of trouble with the PH, but I think ive got that sorted now.
My main questions are:
The instructions say I should run the chlorinator for 2 hours per day, which I have been doing without fail, but over the last few days I started getting large amounts of green algae (I assume) I have hoovered the bottom and cleaned the sides with a brush.
Welcome to the forum.
You may want to check with the SWCG vendor, but running the SWCG for only two hours does not let cell regenerate itself properly. What I mean by that is that the cell receives a reverse polariity to allow any scale buildup on the cell to be removed. Most cells are set up with a reverse polarity change every 4 hours, so you would have to run at least 8 hours a day to get the maximum benefit of the cell. The vendor should tell you what the default reverse polarity is set at, so you can judge accordingly.
I assumed before I came on the forum that the chlorine level is not high enough, which the test stick does hold out, but only slightly low.
You should be getting 3 - 4 ppm.
Should I be removing the solar cover for a cpl of hours each day???
I would remove it for whatever time you set up for the SWCG to run.
Is running the chlroinator for longer going to help my algae problem??
Yes it will, but I would add extra bleach to help.
OR what shall I do??? as the water is no longer nice and clear, its gone a little bit murky...
