I would lik to replace my pump and of course I want to install the proper size.
Is there a easy way to estimate head pressure.
I have a 35k IG poolwith 3 suction and 3 return lines.
Filter psi reading under normal operations X 2.13 + 10 will get you fairly close.
2.31, not 2.13.Quote:
Originally Posted by duraleigh
rosrud, if you get your system head the way that duraleigh says, how will you use it to select your new pump?
