Draining with a cartridge filter
With the amount of rain we've had in our area, I haven't needed to add any water to our pool. I actually could stand to lose some of it and was wondering how to do it. With my old pool I could just backwash the sand filter or set it to waste. How do you use the pump to help offload some water with a cartridge filter??:confused:
Re: Draining with a cartridge filter
most cartridge filters have a drain plug or a hose bib on the bottom to drain water out of the filter. You could open that up and turn on the pump to drain water out of the pool. If the filter is below the level of the pool you might not even need to turn on the pump.
Add a threeway valve somewhere after the discharge side of the pump and add some PVC pipe or a backwash hose.
