Hello All,
I have decided to take the plunge and take care of my pool. I have an approximatley 10000 gallon pool with another 1200 gallons in a elevated spa. We have a Jandy 1400 SWG with a DelOzone system (My Wifes Idea) and other than the Jandy not working at first, we have had little or no problems. After my pool guy didn't show, or return calls, I called and told him not to bother and that he was fired. After doing a little research and getting the pool into shape by adding bleach and CYA, I realized that I could do this myself.
Here is my question, having measured my chemicals this morning, I am wondering if my PH and ALK are too high. I used a Taylor Test kit with reagents for the following results. I took my samples from approximately 12 inches deep in the deep end of the pool.
FC 4 - 5 (My SWG was set to 55%, I have since lowered to 45%)
TC 4 - 5
CC - 0
PH 7.8+
ALK 120ppm
CYA (Testing using a strip identifies between O.K. and low)
The Taylor Kit suggests on their chart that if I wish to lower my ph (1 -2 drop(s) of the reagent to attain the ideal color), I can add around 12 oz of dry acid. To lower my ALK approximately 20ppm, it suggest approximately 2lbs of dry acid.
Do I even need to worry about lowering these numbers?
Your SWG wil operate more effeciently in the pH range of 7.2-7.6. I would not let the pH go above 7.6.
I have heard that with water movement, I have 8' of sheer descents and a spa spillway, that the ALK will lower on its own.
Only if your pH is low....below 7.2 to have any real effect on ALK.
Finally, from what I understand, having a low CYA is better than a high CYA, so is this something to worry about? Is there a more accurate test for measuring the CYA?
Low CYA is not an advantage with a SWG. There have been several threads (and several ongoing ones right now) on CYA levels with SWGs. IMHO, the recommeded range of 60-80 ppm will give you best results.
As far as a more accurate way of testing CYA, the $15 Aquachem test kit from walmart will test more accurately then strips...as will the Taylor K-2006 and K-2005 kits. You seem to have the basic Taylor kit that only tests FC, TC, Acid/Base demand (a useless test....it makes assumptions about the ALK and if not in normal range the demand test results are not accurate), and possibly ALK. You really need a more complete kit. The Taylor K-2006 with the FAS-DPD chlorine test is good...A better 'bang for your buck is the PoolSolutions ps234s available on the sister website to this forum.
www.poolsolutions.com
This kit includes a salt test as well as FAS-DPD chlorine test, pH, TA, CH, and CYA.
Anyway, thank your for your input for a complete novice. I truly do appreciate any thoughts.
Thanks,
Mike
