FC 3.1
TC 3.1
CC 0.0
PH Above 8.2
Hardness 210 ppm
ALK 194
CYA 20
Copper 0
Iron 0
I am also running a gas heater. Is there a concern for calcium or something?
Mike
FC 3.1
TC 3.1
CC 0.0
PH Above 8.2
Hardness 210 ppm
ALK 194
CYA 20
Copper 0
Iron 0
Mike
Assuming correct test results, (pH is usually pretty easy to get right) you need to get some muriatic acid and lower you pH into the 7.2-7.6 range ASAP
All your other numbers are fine, (your Alk will come down with the pH) but you need to get your pH down sooner rather than later.
