Solar Panel -- small bubbles
I installed Solar Panels on the roof about a month ago with automatic controller -- everything has been working well until today.
Today I noticed that I am getting small champagne bubbles in the pool. Any ideas.
The sky been cloudy rainy for a while -- not sure of last time I noticed the panels running.
A new filter has been installed about a week ago and the overall pressure is a bit lower. Could this lower pressure cause the problem of air bubbles. I can see the vacuum relief -- I don't think any air is entering the system there.
Any other suggestions -- nothing seems to be leaking.
Re: Solar Panel -- small bubbles
Do you by chance have SWC? When the unit is on, I get champagne bubbles that dance on the water as well. It's a result of the reaction when the cell is converting the salt (read about it in another thread here)...
Nope -- no SWC.
It's been several hours and the bubble seems constant if not worse. I also placed a bag over the vacuum relief valve. It did not suck in the bag -- so the air is from somewhere else.
Also -- when I shut off the panels -- there is no air -- so the air is from the panel section on the roof.
Any suggestions on how to find where air could be pulled in from?
Originally Posted by jmcst25
Nope -- no SWC.
I was just reading about bubbles and troubleshooting for solar when I saw your post. Here's an excerpt from powermat's site that details this issue:
TROUBLESHOOTING Air Bubbles:
You should see a big flush of air when the solar heater starts up in the morning. It should stop after a few minutes. If air is entering the pool inlets constantly after the system has started up then the vacuum breaker is probably opening and allowing air to enter. Go on the roof and listen to it. You will hear air entering the vacuum breaker if it is the source of the air. If its not, then you have a leak on the pool plumbing before the pump or near the top of the solar panels. Check the pump lid seal. The vacuum breaker is mounted to the bottom header of the bank of solar panels to try and keep some pressure on it so it stays closed. One remedy is to just live with some air bubbles. They don’t affect the system performance and in fact help toaerate the water in the pool. Another remedy is to have the pump serviced to increase the flow though the solar heater. Perhaps the filter just needs to be cleaned or backwashed.
Kudos to Ken W. for a great site & wonderful insights!
Thanks -- I believe I ruled out the vacuum relief valve. I don't see any other sources of air intake on the ground so it may be on the roof. Also -- when I bypass the panels -- I don't get any air -- so I don't think it's a pump / filter leak.
It may be lower pressure? I just had the filter replaced (same 1 HP pump) and the pressure is now lower - I originally thought that was good -- clean cartridges -- but not sure.
Found the readon -- a leak showed on the roof at a PVC elbow. That must be where the air is entering.
Good news I found the problem -- bad news -- I got to get someone on my roof again.
Thanks for all your help.
