Re: Dropping ALK questions
Originally Posted by medvampire
I have a high alk and thinking of dropping it using the sticky thread. My test are as follows.
FC 4
TC 4
PH 7.8
T ALK 200 - 210
Ca Hardness 230-240
CYA 35
Pool volume 13000 to 14000
24’ above ground
22 “ 200lb sand filter with about ½ cup de added
2 hp pump
BBB method
Pool looks great but the Ph goes from 7.4 to 8.0 in a few days. I have a fountain like pictured below.
http://img442.imageshack.us/img442/3708/nt4005fk.jpg
Questions
- Will the fountain I have work?
Sure, it should.
- Can I let the kids in the pool with a ph of 7?
Yes, but no lower. Their splashing (water fights are good!;) ) will aerate the water, raising the pH.- How much muriatic acid should I have on hand for this procedure? (Lowes is 45 minutes away)
I don't think you'll need more than one pack of 2 one-gallon jugs, if that. Remember to keep the M/A in a safe place.- Will the Ca precipitate at this low of ph?
No, just the opposite. It makes it LESS likely.
- What are the long term effects of just leaving it alone and adding acid weekly?
That depends. If you add acid weekly to drive the pH down, the T/A will come down with it. Aeration drives the pH back up without raising T/A--that's why we do it.
If you lower pH to 7.2 each week, your T/A should come down (unless your fill water you add is high t/a).
if you don't lower it that much, your T/A won't come down. You may get scaling, and, if calcium goes up, it may precipitate and you'll then HAVE to go through the lowering procedure.- I am going to salt my pool for that oohhh so good feeling talked about in the other post. Do I need to wait untill after I drop the ALK?
It's always wisest to clear up one problem before making such a change. I don't know that you'll have a problem--you may not, but I do know you won't if you wait until T/A is right.
I am shooting to do the procedure after the weather warms up. I know the fountain will drop the temp and the pool is way too cold (for me) right now.
Thanks in advance
Can't help you with the cold water! Get the T/A down and get a solar cover for AFTER. I think the thickest transparent ones work best. They insulate the most and pass the most light. I've tried the blue ones and the opaque ones and I like this best.
CarlD
I understand about not useing the cover. CO2 has to be able to out gas. I have a blue one but have been to lazy to put it back on. I am gonna build a reel for it next year. I am also looking at building solar heating racks. Just put in a house before the pool so I am going on way too many projects both in time and $$$. I guess I might give the alk drop a whirl sooner than planned. I told the future wife about the salt ideal and you know how it goes. Btw seen your pool the other post very nice.:)
Thanks again
Based on my recent experience, I wouldn't start aerating until your PH has dropped to your target level.
After that, the process works as advertised :)
I was gonna drop the ph to 7 before dropping in the fountain.
Thanks again
Preformed the procedure last week end and it worked. I did adjust the ph to 7.0 every 2 hours. I went from a 220 – 230 ALK to a 160 – 170 ALK in 7 hours. I checked my ALK last evening and the ALK is 140 – 150 with a ph of 7.5. The ph has held since Saturday afternoon. Thanks again for all the great info. My water looks like glass.
