Question about Installer / Permit
I recently bought a 15 X 30 Esther Williams above ground pool and am planning on having it installed "professionally". However, my issue is that I can not find any installers that are willing to pull the permit for it. The company I bought the pool from (reputable) has given me a list of installers which seem to have ample experience, references, etc. and give written warranties up to two years. However, when I called the city, they "strongly" suggested that I not pull the permit myself and find someone that will. Anyone's thoughts on what to do? If I think I can trust the installer, pull the permit myself?
Re: Question about Installer / Permit
like everyone has stated it depends on the installer and the dealer.
One pool dealer told me I didn't need a permit because it is an above ground and can be taken down but another said I did need one if I was going to have electrical and water run to it. I don't have either water or electrical run to my pool. Filled w/ a garden hose and pumps are on a timer that is connected to an electrical cord that goes to my shed. The only thing I remember was the pool had to be 4 ft away from any sold surface (ex , fence , house , shed , patio) and it had to be 3 ft away from any easmant (plumbing line or city lines that they may need access to). My pool is about 3.5 ft from my fence and doesn't go over any easements but I never got a permit. The value of my house will go up and so will taxes. I remember that when I re-did my porch in my front yard.
In the area I work in, Phx, Az. Very few permits are required. When the customer feels they should get one I let them pull it. My feeling is, I do not do the electrical run or the safety fencing that is usually required. I just install the pool. Therefore the homeowner is the general contractor and I am just a sub. I install the pool where they tell me to. The electrical, fencing and setbacks are their concern.
For triple the cost, or better, I could easily become the prime contractor and do it all. I just choose to do what I do best, install the pools.
Later, Dennis
If you care check your local codes, where I am permits are required for any pool -- even a little tiny thing for a three year old!
Up here, an A/G is also not considered a permanent structure and therefore does not require a permit, if you pour a slab, or anything else semi permanent you do need a permit.
