I just bought refills for my testing kit, but all my directions were stuck together and are now a tangled mess of paper.
Is there anywhere on-line that gives the directions for the tests??
How many drops per etc...
Thank!
Carol
Thank!
Carol
What kit do you have?
I took my instructions when I first got them and taped them front and back with packing tape. One year and then some later and still good to go. I don't know where you can get the instructions, but I would imagine that they can be had from the manufacturers website. At the very least you should be able to get a support person to email them to you. Possibly mail another hard copy if you word it right.
I have the HTH 5 way Test Kit.
Most I remember or are easy to figure out but te CA test is muddled. I can't read the fill mark for the larger tube and if you are to add the drops up to the 14 ml mark?
I do remember it took a lot of drops.... thanks for any help. I SHOULD have waterproofed mine!!
Been searching the net, but so far not much luck.
http://www.hthpools.com/Fed/Corporat.../treatment.htm
This is the main site for HTH, but could not find instructions posted.
Wrote them an e-mail and if I get them via e-mail, will post them here for others.
Carol
I believe it should have came with a vial with a flip up spout. This is what you fill with water to the 7mL mark, then add the solution to the 14mL mark. You then squirt the solution into the vial with the black dot in the bottom and wait for the dot to disapear. The corresponding number on the vial with the black dot on it is the number you want.
THANK YOU!!!
Not only could I not read the amounts... couldn't read the bottle number either and was looking at the wrong one!
Now... can you help me find the air leak in my filter??? :-)
Carol- who is happy to be talking pools again!! And so grateful for this forum. Starting out right this year.
