10,000 gal vinyl IG pool, sand filter
FC 3
CC .5 (barely turns pink, clears w/ 1 drop reagent)
TC 3.5
pH 7.6
TA 120
CA 160
CYA 100-ish
Temp 84
Water is crystal clear and feels great.
I usually try to keep the FC over 5 since my CYA is so high. I'm using BBB exclusively and have found it very easy, successful, and CHEAPER.:)
Final question... I just installed a pump timer (had been running the pump 24/7). I set it to run 6 hours in the middle of the night and 3 hours near noon. Is this enough to keep everything stable chemically and to keep the water as perfectly clear as it's been all season? I added the timer to cut my electrical costs (1hp Hayward SuperPump).
