Re: oops.... I used a floc!
Vacuum all that nasty stuff to waste and get it out of your pool. That may help on the cloudy water issue. Pools will get a little cloudy with high bather use.
Ok-well I shut the pump off so it all falls back to the bottom. I closed the pool for the day and I will just keep vacuuming to waste and adding more water to make up for my loss until it is all gone!
Does anyone know if I can use an aquabug on an intex pool? Or any other suggestions?
todays numbers
fc-5-10
alk-180
ph-7.5
cya-30
Yes, I have an Intex pool and have an aqua bug and it works great! :)
Good Luck
Great thanks!! Do you know the model number?
I'm not sure what you're asking...the model # of the aqua bug? I'm not sure - I got the diver dave version from www.intheswim.com.
Hope this helps! :)
That is what I was looking for! Thank you so much.
