salt and chemical maintenance
I have a pool pilot digital salt system in my 3 year old pool. I've had a pool guy open and close for me but he can no longer do it. The new company I've tentatively scheduled told me they use bioguard mineral springs chemical system which requires adding a renewal pruduct weekly. In three seasons, I've never done anything to my water other than check chlorine and PH. It regularly requires acid, which is normal for a new gunnite pool, but other than that my pool water has been completely maintenance free. In fact my old pool guy told me that after he adjusted the water in the spring I wouldn't need any further chemicals.
I'm nervous about using a new pool company and I'm wondering if they're right about adding some new Bioguard type chemical system. Was my pool water missing something in the past even though it seemed fine?
By the way, this is my first pool, but I love the Autopilot.
Thanks in advance
Re:Salt and Chemical Maintenance
Thanks in advance
I would find a company who will close and open your pool without adding ANY chemicals that they feel THEY should use in your salt water pool. They are trying to sell you chemicals you do not need with your present setup.
Your past experience tells me your gut feeling is correct. Many members here will tell you that they changed to liquid chlorine or SWC from Bioguard for that reason.
Hope you have luck in finding a more helpful dealer.
Pat
