Loop Loc cover question/advice
Last Fall I had a loop loc cover professionally installed. My question is what are the procedures for removing and storing the cover. It looks like all I need to do is use the pry bar to remove the springs from the bolts in the ground and then screw in the bolts so that they recess into the ground.
Are there any tricks to the removal process? Is there anything I need to do to the cover before I store it for the summer? Also how long can I wait to open my pool. I live in Alabama the temp. is already in the mid 70's I realize that algae is probably setting up in my pool. However, I would really like to wait another few weeks until all the pollen has fallen from the trees before I open because the pool won't truly get used until late May anyway.
Any advice is appreciated.
Thanks,
Russ
