Advice for Easy Set 12' x 36" pool
Bought Intex 12'x36" pool. Heard that pumps dont work so well. Can anyone give me advice on buying a larger pump to work with this pool (1800 Gal), and how I should treat the pool going forward. Use duckie with Chlorine and chemicals, or use home solutions. Please advise this newbie.
Re: Advice for Easy Set 12' x 36" pool
Can't advise you on the pump and filter, but they do have problems recovering from water problems. My advice is to use bleach for your chlorine source, and run the filter whenever you aren't in the pool. The filter doesn't have great circulation, so you will have a hard time maintaining a chlorine level with tablets, and if you put any powdered shock etc. in you will have a hard time filtering out the cloudiness. Be very careful about adding anything to the pool because you don't have the luxury of a big filter to clean it up.
Originally Posted by brad1974
I'm just trying to help try simplybluepools.com This stuff works great
Disreguard what this guy says. He has spammed another board and got kicked off and now he is trying it here under his SECOND username since he just got booted off with the username simplybluepools.com!
